Need PS Pump Part
Old 04-24-2007, 10:47 AM
Skele4door's Avatar
Default Need PS Pump Part
Sorry to post this here guys, but I'm not having any luck in the WTB section and I figured someone here might have what I'm looking for. I lost the poppet out of my PS pump and need to find a replacement. Ideally one of you guys has a bad PS pump, or got one with your engine pull that is damaged I'd like to buy it. If not, I'd buy a complete pump from one of you that isn't planning on running PS. If anyone can help me out I'd really appreciate it. I attached a pic of the piece I'm looking for BTW. It's located inside the pump and you remove the high-pressure fitting on the side of the pump to get it.
Old 04-24-2007, 01:02 PM
bczee's Avatar
Check with some of the shops (online) that repair and modify Pumps.. they usually have different springs and valve to change the amount of feed back that this valve handles.
Maybe the local Dealer will also have replacement parts. (seem like they would)
Old 04-26-2007, 09:28 AM
Skele4door's Avatar
Thanks for the idea. I assumed they'd need a core for anything that was done, but I was wrong. I ended up getting one that was revalved to work with a Mazda rack for a whopping $20 shipped.
Old 04-26-2007, 09:44 AM
bczee's Avatar
Good news. hope the rest of the project is going well..
