stock or mild carbed combos
when i took mine to the track last year for the first time, it was a 3080lb race weight, 3.27's, 26" MT D/R's, stick, 3000rpm launch & granny shifting it, 6000rpm shift point, it ran 12.63@110.xx.
it was also efi at the time, just to give you an idea even though you asked about carb mph. that was the first & only clean/full pass i made with the car after buying it 3 weeks prior. hope it helps some.
Originally Posted by Darracq
what was your 60ft. maybe my converter kills some mph. I would like to try a 26inch tire instead of my 28s
I am somewhat mild, heads/cam carbed ls1, th350, 4200 tci. Ran 7.06 @ 101mph on a single track rearend. Didn't find out I had blown my posi until i went to install my spool and the carrier shaft (between axles) had seized to the spider gear and twisted which broke the carrier pin bolt. I always knew something wasn't right when I would do a burnout and could only manage to get 1 tire to spin. Should have thrown a big red flag, but I kept on trucking.
Next time out I am expecting 6.50 - 6.70's on the same motor combo. I refabbed my headers (1 3/4) and ported the tubes @ flanges, ported the victor jr, installed a transbrake, installed a spool, finished my cage to 10 point, installed a safety loop, mini tubbed (tires rubbing bad on takeoff), installed full upr double adjustable upper and lowers with antiroll bar.
I think thats about all, I will keep posting with results hopefully next week.
