Tapping sound when warm
Old 04-24-2007, 03:20 PM
SSMaro98's Avatar
Default Tapping sound when warm
Ok so the last weekend. I notice that I get a tapping sound coming more from the bottom of the engine. can't hear it from inside the car. You can really only hear it when next to other cars, outside the car. It seems to go away as the RPM's get higher. ABout a month ago I got LT's True Duals, LS6 manifold and a tune down. My oil in my engine is pretty old but not over due and around 2,100 on the oil in the car. Anyone have any idea what this sound is??
Old 04-24-2007, 03:23 PM
transamfreak01's Avatar
ummm would u be able to put up a clip of the sound? there is a post floating around w/ this in it so maybe try n search but a clip is needed to try and narrow it down
Old 04-24-2007, 05:24 PM
SSMaro98's Avatar
yea I can do that
Old 04-24-2007, 08:44 PM
Disturbedtransam's Avatar
Hope your not having my issue with a spun rod bearing
Old 05-01-2007, 02:03 PM
SSMaro98's Avatar
Oil pressure is great
Old 05-01-2007, 02:09 PM
ls1amit's Avatar
might be noises from the headers they tend to make a more noises. mine kinda does that too but only at lower rpm doesnt sound like a rod nock.
Old 05-01-2007, 05:27 PM
j-dubya's Avatar
tighten your header bolts. probably just an exhaust leak.
jeremy
Old 05-01-2007, 05:45 PM
SSMaro98's Avatar
Same as you thats what it sounds like low RPMs only
Old 05-01-2007, 07:32 PM
SSMaro98's Avatar
Here is video it aint the greatest
http://s175.photobucket.com/albums/w...Picture003.flv
Old 05-01-2007, 08:33 PM
SStheBest's Avatar
hmmm i noticed somthin...ur idle oil pressure for that engine temp seems alittle low...not "alarming" , but low(i have a 224cam w/ stock pump and it cold idles at 50+)....try to tighten up the header bolts....then check to see if u have any loose plugs....i have witnessed this (plugs being loose)
Old 05-01-2007, 09:18 PM
SSMaro98's Avatar
its between 42-50 for me at cold starts at WOT goes to around 60-80. Cam Spring Rods ls6 oil pump timing chain coming soon
Old 05-02-2007, 12:09 AM
ls1amit's Avatar
I wouldnt worry about just make sure you have oil in the car. And if it was a push rod the noise would be through out the rpm. sounds like headers and tru duals just like my car which doest do it as loud. Bottom line i wouldnt worry about it at the moment unless it gets louder, ls1s make noises(your going to go crazy when you get a cam they make some noise as well). But as i said mine makes similer noises but it runs like a bad out of hell. I mean it could be the lots of little things stock tune old plugs. something small.
I knowticed you have a 6spd. If you havent done this wrap your clutch line in tin foil and zip tie it... Also run some seafoam through the car it will clean it out alot its in the general maintanence forum. good luck
Old 05-02-2007, 04:57 PM
SSMaro98's Avatar
Thanks a lot man
Old 05-02-2007, 06:20 PM
ws6pewter's Avatar
does it sound like the cars in this other thread?
https://ls1tech.com/forums/showthrea...7&page=1&pp=20
