napa OEM gaskets
Old 04-24-2007, 05:18 PM
Revelation Z28's Avatar
Default napa OEM gaskets
i went and bought a set of OEM metal gaskets from them, and i checked how they are on the LTs i got and they dont even go on. they have metal tabs on the bottom that show "wrong side" "installed wrong" etc. and the bolt holes dont line up. i thought OE gaskets are good to go
Old 04-24-2007, 06:09 PM
pcgamer4life's Avatar
That's napa for you. Try autozone.
Old 04-24-2007, 06:11 PM
96capricemgr's Avatar
Guessing headers?
Headers generally use different bolt holes at the front and rearmost positions than what the manifolds did. So if you want to use "manifold" gaskets with headers you need to punch holes for the front and rearmost bolts.
If you look at the head there are two boltholes beyond the front and back ports, manifolds use the outer holes headers the inner.
Old 04-24-2007, 06:24 PM
what about the tabs? the gaskets wont even contact the headers with them on, and they dont come off. the guys who use oem gaskets have no problems with the stock gaskets.
Old 04-24-2007, 06:29 PM
Karl Ellwein's Avatar
You can grind off the tabs. Like Dwayne said those are for stock manifolds. But they should work very well with headers too.
If they are multy layers of steel then they are really good gaskets. I think you can make them work. They would be an awesome deal if they did have the holes punched for headers and no tabs.
Karl Ellwein
Old 04-24-2007, 06:33 PM
yea 3 layers.
so i guess ill punch them tomorrow.
theres other holes in the head for headers then on the ends? because the ends are broken off at the head and if i dont need to use thoes holes for the headers then i wont even need to drill them and extract them.
Old 04-24-2007, 06:54 PM
Nope, headers don't use the extra bolt holes at the end of the heads. You can leave the broken bolt in the head if you desire.
Old 04-24-2007, 11:28 PM
TwoFast4Lv's Avatar
NAPA uses Victor Rienz...same as GM
Old 04-24-2007, 11:37 PM
yea saw that when i turned the package around
ok i flattened the flaps with a hammer and i drill punched new holes.
Old 04-24-2007, 11:38 PM
they used to use VR but unfortunatally now they went to FelPro I think.
At least the Maryland NAPA's do not have access to VR anymore.
Karl
Old 04-24-2007, 11:42 PM
TwoFast4Lv's Avatar
That is to bad. I Still have Head gaskets from them Best priced Imp gaskets around
ANyways I know Car Quest still uses VR I just can't wait till GM takes the strangle hold off the LT4 7777 gasket
Old 04-24-2007, 11:56 PM
ellis, you in love with that winking smiley?
Old 04-25-2007, 09:33 AM
TwoFast4Lv's Avatar
Yup!
Old 04-25-2007, 12:35 PM
funny how things time out. We are talking about the Victor Reinz LT1 gaskets and what shows up at my door step? ?? 10 Victor Reinz LT1 head gaskets!
I ordered these through my wholesale supplier and what brought me to posting this fact is:
The gaskets cam from Mahle Clevite Inc.
Now I knew that Mahle bought out Clevite but this is the 1st that I have bennefited from that. Bennefit as in Mahle is damn good at making performance parts and it's always been 1 to 2 days shipping when I buy mahle stuff.
Karl
PS: that LT1 head gasket part number is 5898 (Victor Reinz) Good stuff
Quick Reply: napa OEM gaskets
