TR224 cam which heads 862 or 241?!?!?!?
I plan on getting the TR224 cam and wonder which heads would work better for my setup.
I have a 00 TA A4 4000k stall, 3.73's, pacesetter LT's, SLP lid & maf.
I plan on milling the heads about .030 over and want to get 11's. Which head would be better for my plans, or should I just get some 243's?
Thanks in advance.
Thanks in advance.
I heard that the 5.3 heads (862) will boost compression up but they dont flow as good as the ls1 heads for some reason. Is this true or was I miss informed?
I was going to mill the 241's .030 to boost the compression and keep the same flowing head, but I dont know if I will run in PTV problems. I have a extra set of stock ls1 head at my disposal, or should I buy some 243's?
man ive got some 5.3 heads off an 03 avalanche if your interested....they need to be ported but there complete and clean....they do flow less but the added compression makes up for it....DO NOT PUT STOCK 5.3 heads on your car it wont run right....if your interested pm me...letting them go cheap
Originally Posted by 00BlueTA
just curious how much better the 241's flow than the 243's.
You got that backwards I think. The 243 flow better than the 241. If you already have the 241 and there milled, I would just stick with thows. Your not going to see alot more power with the 243 and that small of a cam.
