LS2 cam in LS1 Question
Old 04-25-2007, 10:01 PM
00BlueTA's Avatar
Default LS2 cam in LS1 Question
My roomate is swaping an 5.7 into his 02 silverado for the 5.3. Will and LS2 cam bolt in or will he run into problems? With the numbers on the cam is it worth it to his setup? He has the LS2 cam, springs, and pushrods.
Thanks in advance.
Old 04-25-2007, 11:26 PM
00BlueTA's Avatar
Sorry what I ment to say was he is running a LS2 cam, springs, pr. It is a stock LS1 bottom end but the heads are milled .030 with stock gaskets. Can he still use the LS2 PR or will he need a different size?
Old 04-26-2007, 10:47 AM
00BlueTA's Avatar
Bump, anyinfo would help.
Old 04-26-2007, 11:48 PM
00BlueTA's Avatar
No one knows???
Old 05-03-2007, 04:28 AM
12oh's Avatar
I think it will work perfect, go for it!
Old 05-03-2007, 07:59 AM
Mike94ZLT1's Avatar
well... yes it will bolt in but it will not work without changing a few things, you need harness adaptors, a new timing cover, an LS2 timing setup.... Why not just get a cam designed for an LS1 and not have to deal with that stuff?
Old 05-04-2007, 08:45 PM
STILL 2 SLOW's Avatar
Is this guy being a smart ***?
Any way I dont think it will work, something about the cam pickup in the wrong spot.
Old 05-04-2007, 08:49 PM
00BlueTA's Avatar
Well I came across a LS2 cam, springs and PR for really cheep. I heard that the LS2 cam was almost the as the LS6 cam. But it looks like the LS2 cam is going to be a pain, so I am looking for a LS6 cam. Thanks for the info.
Old 05-04-2007, 08:58 PM
02silvaZ's Avatar
^ smart move
Old 05-04-2007, 10:19 PM
CJDZ24_Z28's Avatar
yup just keep it simple i heard the 02 LS6 cam can be had for less than $200 new
