mahle piston rings wtf!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 04-25-2007, 11:30 PM
fstls2camaro's Avatar
Default mahle piston rings wtf!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i bought mahle piston rings for my stock ls2 piston the part number is 4005ms-15 but the top ring and second ring fit on the second slot on the piston but none of the rings fit on the top ring slot on the piston?
Old 04-26-2007, 06:42 AM
scatillac's Avatar
Default LS2 Ring Lands
It's probably a set for an LQ9. They have a 1.5,1.5,& 3mm ring package where the the LS2 has 1.2,1.5,& 3mm.
Old 04-27-2007, 03:41 AM
Gregory J. Doyle's Avatar
Hey, I'm looking for piston rings for LS2 pistons too - I am measuring 1.2/1.5/2.5 for the ring pack and checking on the GM performance parts site, thats whats listed for a LS2. Ain't cheap from GM @ 28.00 I think a piston????? Odd ball ring thickness sizes!!!
I'm going to keep looking for some aftermarket, if anyone makes any???
Old 04-29-2007, 12:31 AM
machinistone's Avatar
They are going to cost you about $20/ring set minimum from a mahle dealer. Wiseco also makes those ring packs and they are $28 too.
Old 07-13-2007, 10:48 AM
yobabiesdaddy2001's Avatar
So can you get the stock rings for the lq9 now? If so, where can I get them and how much do they cost?
Old 07-13-2007, 11:03 AM
NemeSS's Avatar
less than 100$ -summit/jegs
Old 07-13-2007, 11:18 AM
Are you sure about that? Do you have a part number?
I have been checking and
autozone cant get them
spdc wants 270.00
Dealership wants 360.00
Old 07-13-2007, 11:40 AM
NemeSS's Avatar
spdc wants 270.00
lq4/lq9 use the same rings only diff. is the piston
crown, where lq9 is tru flat top with no vr's
and lq4 has 7cc spherical dish with no vr's. ring package is the exact same
one.for both engines
pm returned
Old 07-13-2007, 11:41 AM
thanks man!
Old 07-14-2007, 08:48 PM
5150mechanic's Avatar
I got tired of looking and just ordered a set of LS2 rings from my local dealer, $190.00 for a set.
Old 07-14-2007, 09:52 PM
they have them at summit for 90.00
Old 07-16-2007, 04:47 PM
LQ9 or LS2 rings?
Old 07-17-2007, 11:30 AM
KRAZY K 2000 TA's Avatar
wow 190 dollars
Old 07-17-2007, 02:58 PM
Old 07-17-2007, 10:18 PM
$23 a hole, I'm doin LS2 pistons in a iron 6.0, 1.2, 1.5, 2.0 ring arrangement is odd, hard to find.
Quick Reply: mahle piston rings wtf!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
