t56 not slideing in all the way
i am haveing a problem installing the transmission ... it does not want to slide
in all the way it slides through both clutch disks (spec dual) and just stops about an inch short of being in all the way ... pilot bearing is brand new and i am useing a mcleoud bell houseing ... any advice?????????
Try seperating the bell-housing from the transmission. Put the bell housing on the block first and get it bolted down then put the rest transmission on. When done in this manner it becomes much less frusterating. This is less awkward too. good luck
Get 4 longer bolts for the transmission itself, put 2 in on each side that are easily accessible and tighten those down to pull the tranny in the rest of the way, then start putting in the actual transmission bolts, will save you a lot of heartache.
thats a good way to ruin the spline and the clutch friction disks. leave that method to the auto guys.
