which cam before d1sc?
Old 04-26-2007, 04:17 PM
torlak_t's Avatar
Default which cam before d1sc?
guys ive been reading stickies and everything bout cams, ill go mad cos of that much information on the board(thats good though) so my question is, im planning of getting a d1sc for the next summer (2008) but before the charger, i ll need cam, forged pistons and rods etc, so what is your opinions to be able to handle this charger? and also good combination w/o a superchaegr? heres what exoticperformance advise;
http://www.exoticperformanceplus.com....html?item=679
also, it should idle good.
seems hard to decide!
Old 04-26-2007, 04:33 PM
dixonk's Avatar
The blower cam from thunder racing is really good and is only a bit louder than stock but has really good street manners.
Old 04-26-2007, 10:25 PM
userws6's Avatar
I read the Lingenfelter GT11 is good for boosted cars
Old 04-26-2007, 10:29 PM
eamador11's Avatar
contact East Coast Supercharging for their proven custom D1 blower cam. idles nice and smooth...but then get ready to put down 700+rwhp.
Old 04-27-2007, 08:46 AM
torlak_t's Avatar
what about the cam on the link ?(1st post)
Old 04-27-2007, 09:02 AM
LS1 Tech Administrator
Patrick G's Avatar
The EPP cam (232/240 115LSA) is really too big for a 346 IMO. It would be a better choice for a 400+ motor.
The Thunder Racing CheaTR cam and Blower cam are better choices:
215/230 .600/.578 117LSA.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 04-27-2007, 09:12 AM
PREDATOR-Z's Avatar
Hi Patrick,
You really think so? I mean on the big exhaust split, yeah, not necessary, but perhaps on stock heads?
myself I would prefer a 226/230 113 or 114 and let boost do the work.
Old 04-27-2007, 10:00 AM
Patrick G's Avatar
Originally Posted by PREDATOR-Z
Hi Patrick,
A lot of what works best depends on what type of blower they're going to use. A Magnacharger won't want as much overlap or as much DCR as a Procharger, but both will want similar exhaust duration.
The best cam I've seen for an LS1 with a Procharger was a 220/228 .581/.588 115LSA +2. Only -6 degrees of overlap at .050" which makes it emissions legal and the overlap is centered directly over TDC. It's a custom cam.
The Thunder Cams are shelf cams and available to anyone and seem to work well every time which is why I mentioned them above. Like any application, a custom cam will often get that last few hp the customer is looking for, but it's critical to know ALL the info to do it right.
__________________
Old 05-01-2007, 08:50 AM
torlak_t's Avatar
so guys whats the best one for my needs? i m so confused about which cam to buy. i emailed exoticperformance about their cam but nobody replied me back yet. help plss...
Old 05-01-2007, 10:16 AM
Patrick G's Avatar
Best thing is to get advice from the people with whom you're spending money. This way, it's a true partnership.
__________________
Old 05-01-2007, 10:39 AM
torlak_t's Avatar
im not sure which sponsor to chose though. for instance, do thunderracing send outside the usa?
Old 05-01-2007, 11:21 AM
Patrick G's Avatar
Absolutely. Thunder has many overseas customers. Call Todd Brandon (general manager) if you're interested. 225-754-7223.
__________________
Old 05-01-2007, 11:36 AM
torlak_t's Avatar
ok then i ll be in touch with them. thanks
Old 05-01-2007, 12:05 PM
PREDATOR-Z's Avatar
David takes care of me, never a problem.
Old 05-01-2007, 02:17 PM
Irocss85's Avatar
hey guys I used a 216/228 in a customers car with a D1sc and it worked out really well. he would have lost like 3 lbs boost with stock pulleys so you're gonna have to pulley it up to get the same boost level you want compared to stock cam. he already had LTs/catback all I changed that time was cam and swapped pulleys. just make sure whatever cam your thinking of using, you dont run out of RPM (blower RPM) trying to hit your boost level. but the D1sc has alot higher RPM limits then the smaller ones so you'll prolly be fine anything close to 22x's cam duration-wise.
