gr8one99SS
04-26-2007, 07:43 PM
i have a 10 bolt with a trutrac and 3.73 i m gonna try to freshen it up so i need all the torque specs for the ta girdle cover bolts and girdle bolts, main studs and nuts (arp) as well as lca torque specs,phb and torque arm specs i think my suspenion may be to tight causing binding can some one help me out?
Mikerace15
04-26-2007, 08:02 PM
http://fbodyknowledge.org/media/fbodytorque.pdf
that should be every torque spec you ever need.
gr8one99SS
04-26-2007, 08:06 PM
should i use the gm specs with all umi suspension...ooops i guess i left that out, only thing thats adjustable is torque arm
koolaid_kid
04-26-2007, 09:49 PM
Certainly, use them for everything.
