stupid newb question
Old 04-27-2007, 10:44 AM
98zforme's Avatar
Default stupid newb question
Need to add fluid to the clutch master reservoir......Open the cap and most of the reservoir is taken up by a black rubber piece. Do I pour the fluid into the rubber piece or remove it, fill, and replace?
Old 04-27-2007, 10:59 AM
jeffsss's Avatar
common sense would tell you to remove the rubber piece then replace.
Old 04-27-2007, 11:01 AM
Ericbigmac83's Avatar
Yay for common sense. Just be really careful, that stuff will tear paint away in a second
Old 04-27-2007, 11:18 AM
02silvaZ's Avatar
!word!
Old 04-27-2007, 03:36 PM
98zforme's Avatar
I tried common sense, but shear terror overtook me. The reservoir is near empty so the rubber peice takes up 90% of the reservoir. I guess I can just compress it?
Old 04-27-2007, 04:01 PM
Mike44138's Avatar
just pull the rubber piece out. If your reservoir is near empty you've got a leak. Check around the clutch pedal linkage for leaks in the master, and check under the car for a leak at the slave. There's a slit between the bellhousing and gearbox where the fluid will leak out.
Quick Reply: stupid newb question
