Cam specs for my 370??
I got a recommendaton from Cammotion for my 370 and they said 230 int., 234 exh., .604 and .595 respectively on a 112 LSA. They said this would be a max power cam for what I'm doing. It will be a 6.0 .030" over, Mahle flattops, stock rods and crank with the L92/L76 combo. I'm shooting for 475 RWHP with an M6. Does this sound feasible to you guys? Any help or opinions would be appreciated.
LS1 Tech Administrator
You can hit 475 with that cam if you have enough static compression. Biggest problem with L92 heads is getting enough static compression with their large chamber. That cam is certainly not a max effort cam. With only 8 degrees of overlap at .050", it's going to be fairly mild in that large bore motor.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by PREDATOR-Z
239/244 112+2
__________________
A bit of tweaking once on setup will help, proper degreing, quench, DCR and countless tuning hours.
I run a 370 and I'm being held back in the head department myself with a 232/234.
It performs fine but motor can put out more.
However this L92 head thing isn't the best option yet.
I would stick with either properly done 243 or 035 (ie:6.0) castings if budget is a concern.
Otherwise AFR, ETP or RHS would take my vote.
I'm contemplating another head/cam swap over the Summer (too hot for racing, our down time).
Looking at either Livernois stage 3 (243s) or bare PP 59cc 035s with my choice of valves.
Cam will be similar to 240/244 (in that neighbourhood).
I have the 317's that came on it. Do you think that I should just have them gone through? The guy that is going to do my machine work has a flow bench and builds racing engines for a living. I guess I was really wanting to use the L92's because of price and potential. Aren't the 317's what PP uses for their LS6 style heads? If I use the 317's then that cam would be a pretty good choice I'm thinking. I'm wondering if Cammotion has messed with the L92's much yet because what they recommended me seemed kind of small for the flow characteristics of those heads.
Originally Posted by blue by you
I was planning on having the L92's milled to get the CR up around 10.5 or so anyways.
__________________
