Can I beef up the stock rear?
How delicate is the stock 10 bolt? How much abuse can it take? Will hardened shafts and a cover that helps support the bearing caps help at all? Or is it just the small ring and pinion that makes it weak? Can it be strengthened without replacing with a 12 bolt or 9"?
