Finished installing white needle kit & AL bezel
I was having a slight problem seeing my needles at night after I changed the gauge color to green. I found a white/clear needle kit from US Speedo. The kit's needles are a little shorter than ours in the Trans Am/Camaros. After trimming a little of the end where the needle goes onto the gauages they fit fine. At this time I installed an aluminum bezel piece. I accidently cracked the TA's while attempting to cut it free from the clear plastic. Luckily, I had the clear piece left over from a Camaro gauge cluster. Here's some pictures.
Originally Posted by phantomzer0
damn that looks cool. write up!!!
https://ls1tech.com/forums/appearance-detailing/663527-completed-green-led-interior-mod.html
Originally Posted by 94blownz281
when you removed the needles did you have any issues with reinstalling them and getting them to read correctly?
Originally Posted by chaman
Hey finally did it!!! How hard was the aluminum bezel??
Originally Posted by DisturbingDaPeaze
link to demonbirds write up?
Just kidding, glad to help
https://ls1tech.com/forums/showthrea...ezel+installed
