iron block vs aluminum
Old 04-29-2007, 11:08 AM
ruck98's Avatar
Default iron block vs aluminum
what are the pros and cons of having a iron block
Old 04-29-2007, 11:19 AM
black01_WS6's Avatar
about 80 pounds.
You can get soem of the weight back if you go k-mamber and a-arm package.
Iron is stronger, the aluminum is usually more than enough block to tackle what most people want.
What are you wanting to do with it.
Old 04-29-2007, 11:38 AM
PREDATOR-Z's Avatar
I weighed mine 91.3lbs more than ls1 shortblock
Old 04-29-2007, 02:17 PM
lovescamaros28's Avatar
You benefit from weight savings with aluminum block and heads.Iron tends to retain heat which allows for higher combustion temperature=more potential power.Aluminum tends to dissapate or remove heat from combustion chambers.Aluminum is more prone to warpage.
Old 04-29-2007, 04:31 PM
ShowtimeSteeleLS1SS's Avatar
so iron or alum .. i like alum myself
Old 04-29-2007, 05:02 PM
I like aluminum because of the light weight.
Old 05-10-2007, 11:46 AM
ruck98's Avatar
thanks for the feedback guys i was just wondering because i was going to start building a 408 or 402 i just wanted to get some opnions
Old 05-10-2007, 12:03 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
If you are going to keep the car NA or relatively conservative FI/nitrous application go with aluminum arp 2000 head studs and keep the weight down.
-Downside, none cheap and easy to build for a reliable well built and maintained car
If you want to push the block to it's limits get billet main caps and 7/16 L19 Head Studs for it and it's good for a bid more power since they help keep the block from distorting,
-Downside Cost for billet mains, Crank, rods and L19 Hardware, Evans Coolant.
If you want to go crazy get an iron block with billet mains and 1/2" L19 headstuds (but at this power level who cares).
-Downside, Cost Of Billet mains, crank, rods, machine work, L19 componenets Evans coolant and deal with the added weight
If you want to go broke building a Production Shortblock get a Iron block, Billet main, BIG main studs (can't remember size) 9/16 L19 head studs, O-ringed Block,.
- HUGE price tag.
