Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
The little stroker that could..
Old 04-29-2007, 01:31 PM
Mr. B's Avatar
Default The little stroker that could..
The VT 5.0L stroker is in, and stroking away.
I put 2 miles on it.. can't really drive till I get plates.
I'm very happy to report that not one puff of smoke was evident, and motor has great oil pressure and runs nice and cool.
After 30 minutes, I drained the oil and have to do it 2x at 500 mile intervals for the rings to seat.
Here's some pic's and video clips (not the best, but you get the idea!)
Please right click and copy..
VIDEO1
VIDEO2
VIDEO3
Still have a few small things to iron out.. cleaning and polishing jobs under the hood.
Old 04-29-2007, 03:18 PM
Kenny H's Avatar
Are you going w/ a blower?
Old 04-29-2007, 03:42 PM
Mr. B's Avatar
I don't think so.. it's set up for N/A.
Old 04-29-2007, 05:06 PM
Race your car!
JL ws-6's Avatar
sounds tame... good to see it in the car running though!
Old 04-29-2007, 05:12 PM
Mr. B's Avatar
Not too many cam options out there for 4V's.. so I went with the Ford Racing cam kit which included everything, valves, seals, springs, followers (like lifters) and it is proven. The tune makes it sound a bit less lopey then when it was first started. Don't forget, it's only 302ci.
Old 04-29-2007, 05:16 PM
Race your car!
JL ws-6's Avatar
I understand... it's nice and streetable, and should be a big improvment over the stock motor for sure!
small nitrous kit would sure look @ home on it
Old 04-29-2007, 05:35 PM
Mr. B's Avatar
I'm sure a 150 wet shot would make it go..
Old 04-29-2007, 05:37 PM
Kenny H's Avatar
What are your goals for the car?
Old 04-29-2007, 07:10 PM
Race your car!
JL ws-6's Avatar
witha 150 hit that thing will probably move out good.... I'd start at 100 to be a little easy on it... but for sure put one to it
Old 04-29-2007, 08:56 PM
Mr. B's Avatar
Basically a sleeper street/strip car.
When you drive a Mustang, everyone wants to try you.. Honda's, BMW's, GM Cars-of-all-types, even Botox-faced-MILF's in mini-vams!
I gotta be able to say "seee-yaaaa" in second gear.
The bottom end is all forged, so a small shot or low boost probably wouldn't hurt, either. I'd worry more about the T-45 saying no mas.
Old 04-29-2007, 09:35 PM
Kenny H's Avatar
The problem is some of those other cars can be pretty quick. A BMW 335I with the $1300 vishnu package will run 110+ MPH traps....
A power adder is a must....
As long as you don't stick a tire under it and beat the snot out of it at the strip I think the T45 will be fine. If you do decide to upgrade, go right for the T56. I have a tremec and its a little notchy.
Old 04-29-2007, 09:37 PM
Mr. B's Avatar
Perhaps a Procharger next year..
Old 04-30-2007, 05:48 AM
07BlueDevilZ06's Avatar
my 96 cobra i broke 5 trans in 2500 miles shifter forks were the problem just to let you know make sure you have a shifter in there with stops installed thats the only way to stop the forks from braking it always happend on the 1-2 shift then you were stuck driving home in 1st most times also i broke a couple belt tensioners probily they make a aftermarket one now have fun with the car bob
george
Old 04-30-2007, 06:23 AM
Mr. B's Avatar
george
Got the Steeda Tri-Ax with stops.
Old 04-30-2007, 07:08 PM
Specialized's Avatar
Does the T56 bolt right in versus the T45? If so- I bet you could find one used for not too bad- get a full rebuild kit from Six Speeds Inc and call it a day. Those kits are supposed to be good for 750whp or so.
Car should move out, I know those 4v cobras arent as much of a slouch as some of you guys are making them- not fast- but not slow either. I raced a kid with one just after I had gotten my headers on, he hung with me good until about the middle of second, but he had et-streets on, good meaty tires and was launching hard. I was rolling into it at about 2200rpm on my nittos and playing catch-up off the line. I went nuts with him til 2nd there, and then pulled away in third. With a bottle, I don't doubt those cars would move real nice. How much do they weigh?
Old 04-30-2007, 07:50 PM
Mr. B's Avatar
The T-56 fits right in.. d/s might need attention, but it works.
The car weighs 3400 I think.
Old 04-30-2007, 07:55 PM
BTLFEDSS's Avatar
george
Had problems with my shifter forks in my 96 as well
BTLFEDSS
Old 04-30-2007, 11:31 PM
LS1LT1's Avatar
Thumbs up
Nice, glad to see it's coming along Bob.
Old 05-01-2007, 06:28 AM
2MCHPWR's Avatar
cool. how much money are you into the motor for, and what hp/tq will it make at the wheels? get some griggs or maximum motorsports suspension components and take her to the track.
Old 05-01-2007, 06:31 AM
Mr. B's Avatar
Originally Posted by 2MCHPWR
how much money are you into the motor for.
Not much, and much less than a longblock from Ford would have costed.
