powergrip hd with stock flywheel?
Old 04-29-2007, 03:41 PM
bowtierodder's Avatar
Default powergrip hd with stock flywheel?
Can i resuse my stock flywheel with a powergrip hd clutch?
Old 04-29-2007, 04:28 PM
sidewayz28's Avatar
i wouldnt short your self, get the billet steel.. your message box was full so heres your reply to your pm
"hey i had a local guy install my clutch, im pretty sure the shim was installed. ive only driven around 300 miles on it, getting the car rolling in first gear is sometimes tricky, although it is getting better.. if you start off too low in the rpms you get the chatter, or you can rev it higher to get going.. its kinda tricky, i used to ram adjustable master cylinder, which i highly recommend. this clutch is a beast compared to the stocker.. im sure itll hold up fine with ~420-425 hp NA, i just hope it holds up with the extra 125-180hp on the juice"
Old 04-30-2007, 02:28 PM
pwrtrip75's Avatar
stock steel, billet steel, what is the difference? Stock one will do the same thing.
Old 04-30-2007, 02:37 PM
sidewayz28's Avatar
billet steel all the way
Old 04-30-2007, 04:04 PM
1998z28ss's Avatar
If you're looking for cheap just get your FW resurfaced for 30 bucks at a machine shop and use it. Just as long as its not aluminum, ram states that it must be cast iron or billet steel.
Old 04-30-2007, 04:12 PM
The PAT WS6's Avatar
yes u will be just fine me and my buddy have done it on 2 of our rams yes we each have had 2 that make a total of 4
Old 04-30-2007, 10:09 PM
if i resurface flywheel, more than likely ill have to use the shim right? im also doing the adjustable master mod
Old 04-30-2007, 10:13 PM
sidewayz28's Avatar
you should be good to go, and again im not too sure about the shim
