Don - your tank is done
Such as it is. Sorry to say it didn't turn out very good. I sent it home with Dougie jsut now so it's closer to you....I still need to do the straps.
Doug or Mora, can you call me?
And when you see it, know that I sanded it & polished it with the agressive wheel/compound & medium wheel/compound that I bought. When I tried hitting it with the semi-fine wheel/compound I discovered the hole in the wheel was offset about 1/4" and wouldn't work. So (as I said) it doesn't look all that good. Much better than it was, but not what I was after....sorry!
