Buying a 02 ws6 What Kind of H/c package should i get.?
Old 04-29-2007, 09:19 PM
mumu_624's Avatar
Default Buying a 02 ws6 What Kind of H/c package should i get.?
Im buying a 02 ws6 with Pretty low miles...
My goal is 480+rwhp
what kind of Heads and what kind of Cam should i get and
which H/c will give me what im looking for?
By the way i Have LT's....
Need some Help fast....Because im hoping i can Finish it before the end of June!!!!
Old 04-29-2007, 09:27 PM
transamfreak01's Avatar
well do all your bolt ons first, and then look into that but you could do a ms4 with some afrs
Old 04-29-2007, 10:29 PM
DONAIMIAN's Avatar
learn to drive the damn thing first. That much power dosent mean **** if the person behind the wheel dosent know how to control it.
Old 04-29-2007, 10:49 PM
mumu_624's Avatar
i Drove a 410hp ta for a year im sure i can control a 485+hp
Where can i buy AFR heads from or some LS6 heads?
Old 04-29-2007, 11:26 PM
SShawn's Avatar
hellion cam and etp heads.
Old 04-30-2007, 07:12 AM
slow trap's Avatar
look at some of the vendors to the right,quite a few sell heads/cam setups that would get you there or very close. afr 205s,tfs 215s or etp 215s with something like an ms3,ms4 or g5x3 or so should get you close with all the boltons,including a 90/90 setup.
Old 04-30-2007, 07:33 AM
mumu_624's Avatar
I would rather buy some Heads from someone off here..First because it would be cheaper...and Less headache.....
so you your selling some let me know
and I still want some ideas!!
Old 04-30-2007, 07:47 AM
MightyBobo's Avatar
Heads are heads - good ones will still be expensive, even used - and you want good heads if you want 480+ RWHP with stock cubes. How is it less headache? Buying from a vendor is about as easy as it comes.
Old 04-30-2007, 07:53 AM
mumu_624's Avatar
how about If i get my Stock Heads Ported all the way and with a MS4 cam and a LS6 intake and all bolt ons...
how much should i be hitting?
Old 04-30-2007, 08:05 AM
PREDATOR-Z's Avatar
realisticaly target 430>450rwhp for anything affordable.
Otherwise you're looking at mucho $$$ with lots of tuning and expert install.
Old 04-30-2007, 08:18 AM
mumu_624's Avatar
Friend works at a Engine shop...he installs most of my mods...so Labor isnt a problem...ANd tuning isnt a problem either Friend of mine does LS1 and gives me a Deal...
