Barb fitting?
Old 04-29-2007, 09:40 PM
Trunion King
bene's Avatar
Default Barb fitting?
Is that good to use to connect two fuel line hose for my tranny cooler?
Old 04-29-2007, 09:53 PM
8a8mfh's Avatar
What?
Old 04-29-2007, 09:58 PM
Trunion King
bene's Avatar
Originally Posted by 8a8mfh
What?
What did you use to connect the rubber hose from the tranny cooler to the transmission line?
Old 04-30-2007, 06:14 PM
8a8mfh's Avatar
I think it's 5/16 barb to 5/16 inverted flare that goes in the radiator cooler.
And use rubber transmission cooler line, not fuel line, especially if you take it to the track.
Old 04-30-2007, 06:30 PM
Trunion King
bene's Avatar
Please enlighten me why I should use transmission cooler line instead of fuel line?
Old 04-30-2007, 10:28 PM
8a8mfh's Avatar
Because you're connecting a transmission cooler.
because it's thicker.
it will hold more pressure.
it says transmission cooler line printed on it so if you get it inspected at the track it will pass.
because it costs only a few cents more per foot than fuel hose.
because if it breaks and fluid hits hot exhaust your car might catch fire.
But do what you want to, it's your car.
Old 04-30-2007, 10:45 PM
LS1Tech Sponsor
performabuilt's Avatar
Also transmission fluild will cause break down of fuel line rubber and it will burst after a while
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-02-2007, 09:09 PM
Trunion King
bene's Avatar
Cool. Thanks for letting me know. Seriously, thanks.
