Suspension & Brakes - torque arm question
View Full Version : torque arm question
inssane45
04-29-2007, 10:27 PM
I have a 95z its lowered with pro kit. Question is do I need adj t/a or can I use non adjustable. If I get non adj will pinion angle be off.
inssane45
04-30-2007, 09:11 PM
anybody?
JonB
04-30-2007, 10:17 PM
An adjustable is recomended. Yes your pinion angle will be off with a non adjustable. I am running the edelbrock non adj t/a with 1in drop springs. I noticed a difference but i'm sure a adj would make even more of a differnce. Once I get my car back from the body shop I am going to check and see what my pinion angle is I'm kinda curious how much its off.
BMR Suspension
05-01-2007, 08:50 AM
We offer a non-adjustable torque that has some slight pinion angle correction made into it but you are correct the pinion angle will not be optimal.
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
