another koni install ?
Going to be installing my Koni's in a couple weeks. Have been looking over the install docs and reading here.
My ? is with the rear shocks. Has everybody taken the carpet completely off or have they cut the carpet.
If you have cut the carpet could you post some pics so I can have an idea.
Thanks
Thanks
Pat
Just as stated above the carpet is perforated so that you know exactaly where to cut. It looks like there are already flaps cut, but the cuts do not go all the way through the carpet. Just follow the lines with a sharp razor and go from there. Just did my install this weekend.
thanks guys found where to cut. thas where I figured but wanted to make sure. Can I get to the bolts for the install with just a cut in the carpet? Ir... Run into any problems with the install? Any suggestions other than the write up on ls1howto.com.
Pat
