Western Members CA, AZ, NV, UT, CO, NM, HI
Black smoke! Need help Bay area
Old 05-01-2007, 03:24 AM
dans2k1ws6's Avatar
Default Black smoke! Need help Bay area
Black smoke help,
Ok, when I punch it my buddy said he sees black smoke
From the Exhaust, So I took it to my normal Mechanic
He said the car doesn’t sound right and maybe running to rich, so
I take the car to synergy (Rick) he said your car is running fine.
Don’t know what to do
Any Ideas
P.s I think Rick hates me and doesn’t want to fix my car,
Is there any other place to take the car for tuning in the bay
and is good at it
Old 05-01-2007, 07:57 AM
01FbTaWs6's Avatar
sounds rich to me, but im sure its not puking smoke out like its going out of style man
Old 05-01-2007, 09:46 AM
408Maro's Avatar
hmm where in the bay are you?,you may wanna try seafoaming it and see what happens
Old 05-01-2007, 10:34 AM
Juiced's Avatar
Is the smoke Black or A blueish tint?
You can take it to Doug Rippe Motorsports, have you made any changes to the car recently? Take some Brake Clean and clena your maf too.
Old 05-01-2007, 12:13 PM
CaliboyTA's Avatar
newtech performance in hayward ca. does great work.
Old 05-01-2007, 12:21 PM
2 FASST SS's Avatar
My car throws black smoke between shifts at WOT. I'm pretty sure it's nothing major or that a tune won't fix.
Old 05-01-2007, 02:22 PM
dans2k1ws6's Avatar
What is seafoaming.
Fremont.
Thanks guys
Old 05-01-2007, 04:20 PM
408Maro's Avatar
i havent personally seafomed my car but its basiclly a name of a product that you use and you pour 1 can into your gas tank to clean out your injectors and what not from over the years and another can into your oil and brake booster hose to clean out all the carbon build up and what not. that might be all it needs is a good cleaning. i just saw some seafoam at kragens today for $7 a can. search "seafoam" in the search
Old 05-01-2007, 05:10 PM
Intense's Avatar
My car does it to... If its a lot I might worry but it just sounds like a minor output of smoke.
Old 05-01-2007, 07:37 PM
97ssCDB's Avatar
How many miles are on your car? Its an 01 right? My father owns an 01 SS, and has the same situation. 01 cars were known to have bad rings and therefore burn oil. On our 01 car you can clean the exhaust tips, drive for a day and they will be black inside again.Also at WOT it will puff blk smoke in between shifts. But the car runs great overall and has never really given us any problems. Also ours has 130k on it! So im thinking this could possibly be your problem.
Old 05-01-2007, 11:38 PM
transAm-98's Avatar
It may be running a little rich but that's better than runnig a little lean. Most shops will leave a car a little on the rich side when they tune it. Unless you're DUMPING out black smoke at WOT I wouldn't worry about it. It's pretty normal between shifts, especially after doing headers and Y pipe. If it's really bothering you, you could change the plugs and see if it helps.
Old 05-02-2007, 12:45 AM
dans2k1ws6's Avatar
Its got 53k on it.
But thanks
For all the help
Guys
Old 05-02-2007, 01:05 AM
CaliboyTA's Avatar
have u check your oil lately. any oil consumption issues? I live in newark which is very close to fremont. Whats ur a/f ratio from your tune. Puff of black smoke usually means running pig rich. Burning oil should have a bluish tint to it.
Old 05-03-2007, 03:07 AM
dans2k1ws6's Avatar
yea I lose two quarts of oil every 250 mi
Old 05-03-2007, 04:29 AM
6LITEREATER's Avatar
Seafoam is ****... It's a big as smoke show and it's NOT going to fix the problem of you blowing black smoke out your exhaust, period. I honestly doubt it does anything useful but will say it sure as hell is going to fix a problem like yours.
Change your front O2s to some Denso's and throw some new sparkplugs in... That will probably take care of it... If not you need to have your tune looked at.
Old 05-03-2007, 11:34 PM
dans2k1ws6's Avatar
Default Engine could be shot!............ Need help
I stop by and talk to nick @ New tech,
Told him what up with my car and said that my engine could be shot,
What up with that
Old 05-04-2007, 12:51 AM
Azrael's Avatar
What up with that
Did he give you a basis? Black smoke is a sign you are running rich, which is not as bad as running lean by a long shot. Can you be a little more specific in the problems you are having with the car that is causing concern for you?
Are you currently running a tune? Have you put it on a dyno recently? O2 sensors throwing any codes?
Old 05-04-2007, 03:13 PM
dans2k1ws6's Avatar
Default I lose two quarts of oil every 250 mi
He said the car doesn’t sound right and smell’s, he said it’s running to rich so
I take the car to synergy (Rick) he said your car is running fine,
It’s got 53k on it, I lose two quarts of oil every 250 mi,
Last tune was about year ago
yes I did get a code P1133
Old 05-04-2007, 04:11 PM
2 FASST SS's Avatar
What up with that
doubt that's the problem...
Old 05-05-2007, 12:57 PM
CaliboyTA's Avatar
what worries me is that u loosing alot of oil. maybe ur rings are shot.
Quick Reply: Black smoke! Need help Bay area
