Help on with my system
Ok guys again I am in need of your help, I have a custom box that fix down in the trunk part it is for 2 10s. I have 2 volfenhag 800watt dual coilovers that im gonna drop in with a 1000watt volfenhag amp. My question are: Does the box need to be ported? How exactly do I hook up a doal coilover sub up? What would look the best covering the box? Finally do I need a power cap?
Thanks In advance.
Thanks In advance.
Originally Posted by 199TAmaster
Ok guys again I am in need of your help, I have a custom box that fix down in the trunk part it is for 2 10s. I have 2 volfenhag 800watt dual coilovers that im gonna drop in with a 1000watt volfenhag amp. My question are: (1)Does the box need to be ported? (2)How exactly do I hook up a doal coilover sub up? (3)What would look the best covering the box? (4)Finally do I need a power cap?
Thanks In advance.
Thanks In advance.
(2) - Voice coils in series or parallel....then subs in series or parallel with one another in the configuration that will give you the final impedance you want.
(3) - That's up to you.......matched carpet always looks best for mobile applications IMO.....unless you're going for some show car fiberglass setup.
(4) - No.
My biggest thing is the porting I the box Im customizing is ported. Do I need to leave it or close it in?
It sounds like you would be better off sticking to sealed..
