Where to get bolts drilled out in Houston?
the place i used to go to i think closed down (Rick's Auto Works). The engine i just bought, the seller failed to mention the reason one of the header bolts was missing is b/c it snapped off in the head. I also need a motor mount bolt removed from another engine but i can always fabricate around that, so the header bolt is the most important.
Does anybody know of a machine shop that could drill these out for me?
Regards,
Kyle
Regards,
Kyle
iv hae never had any luck w/ easy outs, they always seem to break b/c if the bolt broke off in the block or heads it means its seized/crossthreaded and it needs to be drilled out.
