BMR Torque Arm Relocation Mount
Right now I have a BMR adjustable chrome moly torque arm mounted to the tranny. Have not made my first pass at the track yet and I was just a little worried about breaking some parts with this set up. Is this pretty much a no brainer or do you guys highly recommend relocating it with the BMR cross member relocation bracket. I have around 430 RWHP/380 TQ and I am going to be using MT drag radials.
I think you should be fine with an auto...
When the torque arm is relocated from the tranny to the cross member or chassis, I heard the ride quality is terrible. Is this true?
Also, for an M6, the relocation of the torque arm to the chassis or cross member would cause way less strain on the tranny mount. Is this correct?
Relocating the TA mount off the transmission tail shaft is always a good thing. I run one of BMRs TH400 conversion crossmembers with TA relocation. I did not notice a difference in ride quality or any extra harshness.
My car is obnoxious and loud so I may just not notice it.
I highly reccomend one of these crossmembers.
Originally Posted by SpdFrk1990
I bought the UMI relocation kit also for a piece of mind and I rather not have the TA connected to my tranny. I dont see why it would cause the ride to be more harsh.
I have a BMR adj. TA. and relocation mount. I seem to get a little more vibration but nothing major. I'm also a m6 car and I run about -4 degrees pinion angle.
I use to have a spohn torque arm and i would scrape everywhere since my car is lowered. So i bought umi torque arm relocation mount and bmr torque arm and i have same clearance as stock. I really recommend it if you are worried about clearance issues.
I have the BMR Torque Arm Relocation Mount on my M6 - the installation of the new cross member was easy, the only difficult part of the install was to attach the front part of the TA onto the relocation mount - clearance to get a hand or wrench in there tighten the nuts to hold the TA to the mount was tight but do-able.
Originally Posted by CamaroKid91z
Well was it worth it? How did it ride? Did your car launch better?
I will have mine installed on 5/9/07. I got the UMI one for mine. I already had the Trans tail housing break on a dyno run. What a mess!! I think it will be a good mod to get it off the Trans. I will let you know how it goes and if it gives any issues on ride. I am for now keeping the stock TA though. But who knows I may just get one in the future.
Originally Posted by nick_4.8sierra
OK so the TA relocation crossmember ALSO eliminates the problem of breaking the tranny mount, right???? Because the reason I would get the crossmember is because I broke 2 tranny mounts in the past couple months.
This is just what I think, I have no basis in fact for what I am about to say.
I believe the TA relocation would help with the broken tranny mount issue as you would not have the extra stress of the TA trying to lift the trans off the mount.
Just seems logical to me.
