View Poll Results: flycutt write up
yes
58
100.00%
no
0
0%
Voters: 58. You may not vote on this poll
who wants a write up on flycutting??
Old 05-01-2007, 02:03 PM
SLP4CamaroSS's Avatar
Default who wants a write up on flycutting??
in abotu 2 weeks im goign to do my cam swap and wondering who wants a write up on flycutting?
SLP4CamaroSS is offline
Old 05-01-2007, 02:08 PM
Irocss85's Avatar
I actually did a complete writeup, then went to bed. well, somehow I lost the whole F'n thing. and said screw it. I bet alot of people would benefit from it if you take the time to take all the pics as you go, and do a good writeup with illustrated pics. if you got the time go for it.
Irocss85 is offline
Old 05-01-2007, 03:38 PM
erikthegoalie's Avatar
it must be detailed....specially how to measure the depth of the cuts....if its good you'll prob get a sticky, that is bad A
erikthegoalie is offline
Old 05-01-2007, 04:15 PM
styoung's Avatar
hell yes, that is a great idea!!!
styoung is offline
Old 05-01-2007, 08:25 PM
onebadZ28's Avatar
YES, finally someone stepping up to the plate. I would think alot of people could benefit a great deal from this especially myself. But, like one member already said it must be very detailed with good pictures of the whole thing. I voted YES to this but, it going to be time consuming for you to do this. But just imagine all the people you would help out
onebadZ28 is offline
Old 05-01-2007, 09:13 PM
chuckyt1's Avatar
Yes! So many people are afraid to do it and it really isn't that big of a deal. Post it up and help a lot of folks out...
chuckyt1 is offline
Old 05-02-2007, 12:06 AM
Mr.MartyStone's Avatar
That would be a huge help to a lot of guys still on the edge about doing it. Hookin up tech for the greater good.
Marty
Mr.MartyStone is offline
Old 05-02-2007, 12:11 AM
L67toLS1's Avatar
i hate feeling like the noobie but wtf is a flycutt?
L67toLS1 is offline
Old 05-02-2007, 12:33 AM
Blk97WS6's Avatar
I agree with everyone. A good write-up on flycutting has been needed for awhile, tons of people would benefit from it.
Blk97WS6 is offline
Old 05-02-2007, 12:36 AM
fastest94v6's Avatar
I shouldn't exactly say cutting...but in a way sorta shaving the piston in order to gain proper PTV clearance.
p.s. I gotta imagine that it has to weaken the piston some what.
fastest94v6 is offline
Old 05-02-2007, 09:46 AM
Irocss85's Avatar
I wouldnt recomend it with boosted cars. caus they run hotter chamber temps and would apply more press.. but aside from that, TONS of people have flycut the stock pistons, (one guy cut .140" I think was the deepest Ive seen) and not a single failure that Ive ever seen. plus, most cams wont require that deep of a cut. I cut .120" from the intake side but thats only cause I milled the head .033" and .040 head gasket AND 235 LSK lobe cam with 110 ICL. all that adds up to needing a deep notch.
I have pics to contribute when I get home during the weekend.
Irocss85 is offline
Old 05-02-2007, 10:12 AM
PREDATOR-Z's Avatar
Write one, we will help then I can sticky it for ya.
Pics as you go a must.
PREDATOR-Z is offline
Old 05-02-2007, 12:35 PM
dscott's Avatar
Yes, but at the same time I'd be more interested in knowing how deep we can go on stockers. I mean how much does this weaken the piston? If I did it, could I still use N2O? Someone has already mentioned boost, nitrous does the same thing heat-wise. I'm only afraid to do it for this reason, I have no problem with the actual process.
I may have to change my cam choice (MS4 - Stg 1 LS6 heads). Currenly in the middle of the swap and having trouble deciding.
dscott is offline
Old 05-02-2007, 12:39 PM
dscott's Avatar
Oh, and don't forget to smooth the edge off the cut!
dscott is offline
Old 05-02-2007, 12:49 PM
PREDATOR-Z's Avatar
Yes you can use N20 on flycut pistons, just deburr properly to avoid hot spots.
.080 is a good flycut on stock pistons and still leave plenty meat.
That is ~ 1cc
Old 05-02-2007, 01:15 PM
aNuBiS's Avatar
Yeh, I did .080 on intake and exhaust so total 2cc per piston
aNuBiS is offline
Old 05-02-2007, 02:46 PM
That is ~ 1cc
so it won't cause any harm will it?
Old 05-03-2007, 12:11 AM
Xtnct00WS6's Avatar
I might be having to flycut soon so maybe I could help out too
Xtnct00WS6 is offline
Old 05-03-2007, 12:21 AM
im just waiting for my valve spring set/flycutting tool/ gaskets/bolt they should be here next week then i get to start
Old 05-03-2007, 03:39 AM
Restricted User
WS6nJAX's Avatar
recently went back in and notched mine. the first pic shows why i had to go back in. the silver looking slash on the piston is from the intake valve making slight contact. the next pic is of the finished product. the final pic shows the half-dollar that i used as a reference when cutting. i found the half dollar to be really easy to use when checking depth of the cuts.
WS6nJAX is offline
