LSx timing/pointer indicator???
Old 05-01-2007, 06:56 PM
tomulrich's Avatar
Default LSx timing/pointer indicator???
who makes a timing indicator/pointer for the LS motors?
Thanks Tom
Old 05-02-2007, 04:25 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Moving to internal. I have no idea either. Maybe Moroso?
Old 05-02-2007, 08:44 AM
Grimes's Avatar
humm, are you running a motor with a distributor? I guess that's why you need to have an indicator? If you can't find anything for sale, you could always mark the factory damper to use with a timing light.
or are you looking for a cam degreeing kit?
Old 05-02-2007, 08:59 AM
tomulrich's Avatar
BS3...need to confirm timing.....I need the indicator not the balancer...I have a marked ATI dampner
Tom
Old 05-02-2007, 12:39 PM
Lason's Avatar
The problem is the LSX balancer's arent keyed so there is a chance it will spin on the crank and the timing marks will be off. You could make one if you wanted to using a small piece of a coat hanger.
Old 05-02-2007, 05:49 PM
tomulrich's Avatar
mine...is keyed....I wouldnt be asking for a pointer if the crank wasnt keyed of I didnt have a balancer that was marked
Just need to know if anyone makes one....
Tom
Quick Reply: LSx timing/pointer indicator???
