Built T56 with a 2 Step?'s
Old 05-01-2007, 11:22 PM
HUNTER02SS's Avatar
Default Built T56 with a 2 Step?'s
Has anyone ever tried this.If so how did it work out for ya.Looking to uprade my trans and needing this question answered before I decide which way to go with it!.Thank's
Old 05-02-2007, 08:00 AM
wrencher
wrencher's Avatar
I use a 2 step full wieght car McLeod twin disc on E/T drags.
I usually leave @ 5500+.
I build my own trans, it has been in the car 3+ years, no problems.
I powershift it in the run as well.
I hold the throttle down at the line w/the 2 step & dont let up till the finish line
Old 05-02-2007, 08:27 AM
HUNTER02SS's Avatar
Sweet, This is exactly what i am wanting to here!!On my turbo car I am wanting to make sure that I can build boost with it at the line.thank's.
Old 05-02-2007, 09:04 AM
ls1 joe's Avatar
We use a harlan 2 step and have for 4 years. We launch anywhere from 7000-8800rpms without issues. Of course this is a face plated transmissions.
Thanks,
Amber
Old 05-02-2007, 09:22 AM
HUNTER02SS's Avatar
This is great new's!! Keep them coming!
Old 05-02-2007, 05:13 PM
Restricted User
2001 Pewter WS6's Avatar
Thanks,
Amber
Where do you have the activation switch coming from??? The black switch when the clutch is pushed in or the white switch when you release the clutch???
Old 05-02-2007, 07:38 PM
stevieturbo's Avatar
Whats the difference with a face plated transmission ?
Old 05-02-2007, 07:57 PM
ls1 joe's Avatar
The gray wire off my 2-step goes to pin 32 on the blue connector, which I think is the white upper switch.
Face-plating gets rid of the blocker rings, and enables high rpm powershifting without damage. I have 100 passes on my faceplated rings with no issues. Here is a brief run down of what faceplating is.
Pro shifting and face plating serve the same basic purpose, a bigger window for engagement to prevent missed shifts. Neither are synchronized, so they make street driving difficult. Contrary to popular belief, YOU MUST USE THE CLUTCH when shifting with either system. Although it is mechanically possible to shift without the clutch, the shock load of a clutchless shift can cause severe damage to the transmission. We do manufacture a clutchless transmission with a starting price of $7580.00.
Face plating is preferred over pro shifting, but it slightly more costly (initially) than pro shifting. In the long run you will find that face plating is more cost effective due to less wear on engagement components.
With pro shifting, as the pro rings wear from normal use, they burr up and require dressing, deburring and/or replacement to maintain smooth shifting.
With face plating, the engagement lugs are on the face of the slider and the lugs also have a much larger contact area, so in the unlikely event that they burr up, it will not affect shift action. Due to the design of the shift lugs they are more durable, so longevity is increased dramatically (about three to four times longer than a pro ring) and there is virtually no chance of popping out of gear making for a much more streetable set up.
Old 05-02-2007, 08:03 PM
So its a dog box then....
Old 05-02-2007, 08:17 PM
ls1 joe's Avatar
Yes it is
Quick Reply: Built T56 with a 2 Step?'s
