need 232 595 112 cam sound clip
looked around on the vid section but wouldnt find anything....just wondering if anyone is running the 232/232 595/595 112 comp cam and if they have any sound clips of it idling. ill be puttin one in in about 3 weeks but am anxious to get an idea of what itll sound like.
where did you get the cam from? Not to scare you but i guy in town had one with those specs, and it came from MTI. Turns out it wouldnt fit and wiped every valve in the motor. Might wanna double check before you put it in. Good luck though
There's a crappy video on LS1 sounds I just found 5th one down that has almost exact same specs and is a Comp cam: 230/232 591/595 112lsa http://www.ls1sounds.com/camshafts.htm
F13 cam specs are 230/232 595/585 112 are also similar. Should sound pretty close to what your looking for to give you some idea. Plus it will depend on the exaust system too.
