New Deck and Static noise HELP Please
I Installed a panasonic deck on friday and theres static noise in the background all the time its not that loud but its very annoying, especially when changing songs and all you hear is static. My buddy has the same deck and his does'nt do this hes got no static noise at all. There was a bunch of wires in the back I think there called rca's and two of them didnt have the little plastic caps, the caps arnt on there because my buddy who I got the deck from was running an amp and Im not like the others could this be causing this noise my the two touching each other? Right now Im really confused On what it causing this, Ive used a cd cleaner disk and it did nothing.
Any help would be great.
Thanks in advance
Ryan
Thanks in advance
Ryan
Is this at every location at all times or have you just tried it in your driveway or something? Sometimes more sensitive HUs will pick up additional noise caused by power lines, etc -- might be a setting to help fix this on your HU.
Check all connections first, make sure everything is clean. Is the antenna adapter snug (is the antenna itself screwed in well also)? This is more stiff and comes loose somewhat easily sometimes installing the HU, etc.
sounds like a bad ground to me. OK turn on the radio, turn the volume down to like 3, then rev the car. IS there a difference in the static? let us know. Little by little we can diagnose the problem.
hey guys, the static is all the time in every location, even when the volume is at 3 and I rev it the static stays the same. Could it be the rca's ends touching each other?
Thanks guys
Ryan
Thanks guys
Ryan
Bad ground. My car is doing the same exact thing. I grounded my HU into the factory harness ground. I need to go and change the ground to an actual chassis ground. That will solve my problem and possibly your`s.
Jebcamaro, I also used the factory ground, makes sence to ground it better, do I have to ground it to the chassis or can I ground it to a Piece of metal in the interior.
Thanks for the help.
