Fuel pressure problem
I did the 3.4L to ls1 swap in a 94 camaro and im only getting about 40 psi of fuel pressure and i need 60. I was thinkin that i just needed to change the fuel pump to an ls1 fuel pump but i was told they were all the same and i needed an adjustable regulator, but im not sure what regulator i should get? Would an lt1 adjustable regulator work, if so wheres a good place to get one?TIA
