pvc and cr question
Old 05-03-2007, 10:05 PM
customz28's Avatar
Default pvc and cr question
just bought a 383 setup using eagle crank, rods and JE pistons........the pistons are -2cc dished......i was wondering if id be alright with piston to valve clearance running prc ls6 heads which have 63cc chambers i beleive with my torquer 2 cam......also what will my cr be around? thanks
Old 05-04-2007, 03:53 AM
PREDATOR-Z's Avatar
With stock gaskets and assuming your piston position is .005 (out) it should be around 11.5:1
Yes the TV2 will fit no problem, I would get a 112+2 LSA
Old 05-06-2007, 08:40 AM
customz28's Avatar
awesome, thanks a bunch
