Help...ballpark a figure
I have a '00 V6 bird. I want an LS1 or LS2. I'm thinking about just using my T5 (probably rebuild it). Any of you guys have a ballpark figure for how much the whole thing would cost after I got all the necessary parts NOT including the engine or tranny? And approx. what would somebody charge to make the swap? Any help at all is appreciated. Thanks
Would suggest to forget about the T5 if you switch to an LS1 or LS2. Complete used LS1/T56 combo w/ headers, ECU, wiring, ....etc. run around $3K to $10K depending on mileage & year. The swap labor could run from $1,800 to $3,000 including modifying the exhaust. If a new exhaust is needed, it will be more. Of course, these are ballpark figures. You may also consider selling the 2000 V6 Bird & buying a 00 V8 Bird. It may cost less. Good luck
Good Idea...
