lca bushings... is there a cheaper way?
hello
right now i have the stock lca bushings. I want to upgrade and ive heard that poly/spherical combo are the best. However i cannot justify that kinda money for just bushings. Is there a cheap alternative that doesnt work bad?
thanks
Speed
thanks
Speed
I'd just replace them with tubular LCA's, they already have poly bushings in them as well. I believe a couple vendors have them on here for like 129 bucks for the set. Price just depends on what kind of ends and if they are adjustable etc...
LS1TECH Sponsor
I agree, and it' what I have in my car. A set of 1LE's are just over $50 for a set of 4, and eliminate the air gaps that allow bushing movement..... Just pop them in the stock arms and roll.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
I just put in a set of Moog/1LE type rubber bushings. It was not so hard. You can do it without a press. I can link you to some removal/install directions if you want.
