MSD Ignition problems
I just put in a LS364 in a 1967 camaro with a MSD ignition 6LS-2 controller. MSD has included several plug in chips for advance timing control. This controller also has the ability to map a timing advance curve with MSD’s easy-to-use Pro-Data+ soft ware via a lap top computer. Does anyone have any experience with this? Is it worth my time to use the so???are or to stick with the plug in chips?
I like to mess with timing curves so the 6010 box works best for me, Right now i have mine sets at 32 from 1200 rpm to red liine, runs real good there, If you ever want to run nitrous then you would want the adjustable box.
