Any suggestions on why my car mississ and stutters???!!
Old 05-04-2007, 08:20 PM
Eatinstang4life's Avatar
Default Any suggestions on why my car mississ and stutters???!!
Well just got my rear mount tuned today on 5psi it made 418rwhp. I am happy with that considering I built everyting my self. But It stutters pretty bad if I nail it at low rpm, its fine if I gradually give it gas and pulls like a biotch. The air/fuel is right on the button through all rpms. I'm thinking it could be the plug wires, I did put some tr-6's in a couple days ago, the wires are only couple month old. I checked to see if the boots were on the coil and plugs all the way. I guess I could pull the plugs to make sure they look ok. Any other suggestions would be great. Thanks guys
Old 05-04-2007, 08:51 PM
BigBenz's Avatar
what stutters the car or the motor. What gear will it shutter in when you nail it?. Your not talking about the diesel effect? like when you start in second and floor it? I dont know what you mean by stutters. is it missing? Tr6s i hear foul real fast if your tuning isnt good. maybe turbo lag? try reving it to 2.5k rpm then lettig it run.
Old 05-04-2007, 09:51 PM
Sounds and feels like the motor is miss fireing. Its most noticable in 4th, but feel it in 2nd and 3rd also. Ill hit it about 2k than it will stutter than when boost comes on everything is normal feeling.
Old 05-04-2007, 10:07 PM
NYSS Guy's Avatar
Are you scanning any data? Getting any knock? Are you running a 2 bar setup? The one thing I can think of is that you are getting too much fuel at any boost level below 5 psi. And that is causing the miss. But, if you're running a 2 bar setup, that wouldn't be it.
Old 05-04-2007, 10:24 PM
BigBenz's Avatar
sounds like there is something wrong with the tune. Take out your plugs take a good pic of them and post it.
Old 05-05-2007, 12:11 AM
BigBenz's Avatar
you know i was thinking is it a STS kit? i hear alot of oil getting in the manifold.
Old 05-05-2007, 05:47 AM
2001WS6Vert's Avatar
If it feels like a mis-fire just scan it so you can at least find which cylinder is giving you the problem.
Old 05-05-2007, 05:55 AM
cablebandit's Avatar
maybe a cracked plug
Old 05-05-2007, 07:06 AM
We were scanning it on the road the air fuel is ratio and pefect steady around 11.4-11.7. I am going to pull the plugs tomorrow whe nI am off work. I do know if any oil getting through I have a catch can.
Old 05-05-2007, 09:56 AM
BigJls1's Avatar
My buddys car did the ezxact same thing.
The MAF was getting covered in oil .
We cleaned it with the maf cleaner and it would run awsome, after 3 or 4 hard pulls it would run just like you said it would kinda chug at the low rpm in like 4 gear when he would floor it.
clean the maf and the condition was gone. finaly we used a restrictor in the oil supply line and steped up the 1/4 return to 3/8 line. Now hes been driving for two or three weeks, no problems. Howerver your car seems a little rich at 11.7 try like 13.3 or so, you may be going from a rich cruise condition to when you floor it a lean condition causing it to knock and retard timming. you then lose a bunch of power and the chugg-a-lug begins.
hope this helps, 20 minuntes to remove and clean the maf is were I would start.
Old 05-05-2007, 10:09 AM
pdanrichey's Avatar
Sounds to me like the tune. What's your timing curve look like? I had some issues on my first tune. We took out too much fuel b/c of how rich it was running at idle. So, as soon as I would floor it, the car would cut all gas for a split second, then pour it in and the car would haul off.
BigJls1...are you freaking serious??? 13.3 AFR on a turbo car?? Bye-bye head gasket! Everything else in your post makes sense, but now I have no respect for you... j/k But seriously, you can't do that...
Old 05-05-2007, 05:24 PM
Just pulled my spark plugs out the electrodes are whitesh grayesh on all of them except number 7. If they look white its runnig lean right? But We have checked the tune over and over its all good throughout all rpm ranges under load and normal driving. I am stumped
Old 05-05-2007, 11:40 PM
BigJls1's Avatar
dude,
clean your maf , do it.
Old 05-05-2007, 11:48 PM
BigJls1's Avatar
I thought he was talking about @ Idle not on boost. I then re-read it before I called you an idot, but I am in fact the idot. But at 5 psi with cold plugs and 91 octane I think 13.to 13.5 you can get away with now 8 psi differnt story. however I will admit thats a comment not for this thread.
Old 05-06-2007, 01:02 AM
BigBenz's Avatar
Is it a STS kit? You boost the crank case and send oil into the TB. I bet your sending oil to the cylnders. That would make it run messed up. Check your MAF>
Old 05-06-2007, 10:37 AM
BigJls1's Avatar
Thumbs up
Thats what I'm sayin..................
Old 05-06-2007, 02:27 PM
Checked the MAF yesterday sorry forgot to post there is no sign of oil in the maf AT ALL not even moist. I forgot to mention When I pulled the plugs one of them the gap was closed to like 18-20 I guess from install I must have taped the electrode, Maybe that was causing it. Any other suggestions?
Old 05-06-2007, 06:20 PM
BigBenz's Avatar
2x post
BigBenz's Avatar
You know the PVC vent that connects to the TB?Its on the bottem of the TB on the passager side. Do you have a check valve on that?
and is it a STS kit???????????
Old 05-06-2007, 08:40 PM
Yea check valved the pvc system. I built my own rear mount set-up like the sts kit.
Quick Reply: Any suggestions on why my car mississ and stutters???!!
