f13 to ms4 worth the time?
thinking about changing cams and I keep reading good things about the MS4 so would it be worth the time and money to do the change..the car is drivin very little but I still want it to have street mannors and I will be sprayin it and of course I want it as fast as I can I have the TSP 5.3 stage 2.5s
You alreeady have the heads on? The MS4 a good difference in size over the f13... Itll probably make a good 10 HP over the f13, but youll definately need to spin it up high to see the gains. Im sure itll lose a good bit on the low end too.
Unless youre money is easyto come by and you happen to be in the engine anyway, i wouldnt this its worth it either....
I am in agreement with everyone else I would not change to the MS4. With the MS4 you probably will need new valve springs as well. That cam has close to .650 lift.
