885rwhp/814rwtq-little CDN 347 and F1R, need more fuel!!!!
Old 05-05-2007, 01:17 PM
eb02z06's Avatar
Default 885rwhp/814rwtq-little CDN 347 and F1R, need more fuel!!!!
Well I put a boost sensitive regulator on the car on hopes I could bandaid the situation for my lack of fuel for Norwalk. No go-but what I did find was my last blowoff was opening under boost a tad-so we installed a new Procharger Race blowoff. Same old deal only it happened even sooner-AFR was 10.1 up to 5500 where it started to climb to 11.5-we stopped the pull around 5800 as my AFR warning light is programmed to come on at 11.5 AFR. Injectors are 130% duty cycle at 5000 rpm-boost is 20-guage only reads to 20-time for a new boost guage. Same 4.13 pulley-blower RPM is only 65000 at 6800-max is 74000-no slip. This why the car is just plain "Stupid" on the street. Time for 96lb's, a driver box and some dual walbro's-no matter what we will be at Norwalk. Rodney-please get my spare ready! Dave(Sled28's)-thanks for the stout motor. Bob(EPP)-these F1R's rock!!!!!
Old 05-05-2007, 01:37 PM
LS1Tech Sponsor
hellbents10's Avatar
Very nice time for that driver box huh, I love how you are doing it through a 65 too.
Old 05-05-2007, 01:51 PM
venom ws7's Avatar
Damn man those are bada** numbers what are your goals at the track?
Old 05-05-2007, 02:00 PM
94snake's Avatar
Sick! Like hellbents10 said, just amazing #'s thru a 4L65E!!
Old 05-05-2007, 02:17 PM
SLED28's Avatar
Can we fit one in my Camaro 8)
Old 05-05-2007, 02:27 PM
Coal Mining Director
onfire's Avatar
Which fuel pump are you running now? What base pressure?
Old 05-05-2007, 03:10 PM
eb02z06's Avatar
It's the Bosch 044, base pressure at 58 psi-it ramps up to 75 psi then drops to 40 psi. Lonnie from LPA is making me a Dual Walbro setup-he wants me to try that first before doing line, rails or a driver box and low-imp injectors.
Old 05-05-2007, 03:18 PM
LS1Tech Sponsor
Slowhawk's Avatar
Throw the Z06 line in the trash and put in a -8.
Are you running meth? bigger jets?
Old 05-05-2007, 03:23 PM
eb02z06's Avatar
Hey bro-where have you been? Running the 97-98 lines-so a 3/8 feed and 5/16 return-Lonnie wants me to try the dual pumps first before attacking the lines and the rails-this way if we do it all and it still doesn't work I won't be scratching my head.
I'm running the dual nozzle Alky from Julio-I beleive one nozzle is a 15 and the other is a 10. IAT temp is goes from 75 to 45 degrees.
I saw that you had good luck with the Accelronics and the 96's?
Old 05-05-2007, 03:43 PM
qqwqeqwrqwqtq's Avatar
Great #s! I believe your feed line is sufficient as we've made over 1,100rwhp with a stock f-body feed line.
Old 05-05-2007, 04:33 PM
HUNTER02SS's Avatar
I believe you are going to need 2 bosch 044 for that power level. I have 2 of them and no problem's.Also using 60lb mototron injector's and everything is great.Congrat's on the #'s. That 347 is screaming !!!
Old 05-05-2007, 05:39 PM
2001WS6Vert's Avatar
Nice #'s, your gonna make all these turbo guys switch back to blowers.
Old 05-05-2007, 05:54 PM
hashtagBMW
Speed Density's Avatar
Nice!
Car is making some serious power man, keep it up!
Tony.
Old 05-05-2007, 06:05 PM
stevieturbo's Avatar
Id agree. The Walbros can not handle the same sort of pressures the Bosch will.
The Bosch will maintain excellent flow rates even up to about 100psi.
The Walbros start to struggle over 70-80psi or so, and flow rates drop off quite a bit.
Im using 2x044's at 63psi base pressure, ramping up to 82psi at max boost ( 19psi obviously ). My fuel pressure is rock solid.
Old 05-05-2007, 06:36 PM
eb02z06's Avatar
Unfortunately I cannot fit 2 Bosch pumps in the tank. Lonnie says he has guys making 900 rwhp with the Walbro's so we'll see. We'll take it step by step. Do you guys have pics of your dual Bosch setups? I need to keep this setup clean and simple and most off it has be able to be daily driven.
The thing that strikes me as really weird is the bosch pump holds pressure fine at 75psi, then immediatley drops to 40 psi at around 5500-no gradual decrease or drop just slam.
Old 05-05-2007, 06:47 PM
Got Me SOM's Avatar
congrats, please get some videos. be careful that's a lot of power on the street!
if you are dropping fuel press that fast so suddlenly, you might wanna keep your foot off the pedal. even forged motors can be blow'd up!
Old 05-05-2007, 07:13 PM
EPP
EPP's Avatar
Smile
No doubt! Once you get the fuel system resolved, your next hurdle will be trying to keep the car together! lol Bob
Old 05-05-2007, 07:15 PM
Outlaw1's Avatar
That's what I like to hear.
I'm getting more and more anxious to get this engine done so I can get my car together.
Old 05-05-2007, 07:16 PM
chriswtx's Avatar
Maybe its your fuel pressure regulator that cant hold the 75psi...
Old 05-05-2007, 10:09 PM
I agree that the walbros will work great.
Quick Reply: 885rwhp/814rwtq-little CDN 347 and F1R, need more fuel!!!!
