What is the best way to remove roll pin?
Old 05-05-2007, 10:29 PM
berger21's Avatar
Default What is the best way to remove roll pin?
Ok. I got the tranny out. Now I need to remove the extension housing. I believe the isolator cup assembly must come off to do this. There is a roll pin holding this assembley on. Does it need to be drilled out? I can not seem to get it to budge?
Old 05-05-2007, 11:40 PM
LSGunZ28's Avatar
a punch and a brass hammer or a regular hammer.
LSGunZ28's Avatar
if you dont need to remove it, dont remove it BTW.
Old 05-06-2007, 12:10 AM
SShawn's Avatar
yea punch and hammer will do. then just a hammer to go back in. you will have to take it out otherwise the main case will not slide off.
Old 05-06-2007, 09:47 AM
berger21's Avatar
I was concerned when I use a hammer about bending the rail it is attached to.
Old 05-06-2007, 10:21 AM
SShawn's Avatar
it will come out fairly easily. if your that worried about it, support thr shaft with something.
Old 05-07-2007, 09:57 AM
berger21's Avatar
Once I hit it like a man, it came right out.
