Paint & Body Work - TA Headlamps
View Full Version : TA Headlamps
SamD_Ind
05-06-2007, 11:49 AM
I was wondering if there is a wat to stop the headlight from flipping up/down then you arm/disarm the alarm system using the key fob?
thanks
Sam
2001somws.6
05-06-2007, 12:20 PM
Is there a sound coming from the lights when you use the keyfob? If so your gear in the motor is striped and you will have to fix it.
Drew's TA
05-06-2007, 02:18 PM
sorry dont mean to hijack, but the same thing started to happen to mine 2 days ago, making the grinding sound too. How do I fix this, is there a guide somewhere?
06TDI
05-06-2007, 02:54 PM
The gear is stripped inside, do a search, you will find lots on it. Everything from replacement of the motor, to putting brass gears in, to turning the stripped gear around to catch the other side. Only 1 side of the gear is stripped.
