help with changing 1speaker
To pull the grille cover off....well that's it -- literally just pull it off. Just kinda use common sense to manipulate the tabs so that you don't break one. This should take 5 seconds per side using hands only -- do not try to pry there with a tool -- you will just scrape up the plastic.
Yes, unlike the fronts, the grille only needs to be removed...you cannot just pop the grille off on fronts (door must come apart) -- you will crack it and you can't get the speaker out through the small space -- just fyi in case you try just removing the grille for the fronts as well.
