How much power will twin 2.5" IC tubing support?
This is for my twin turbo setup. I was thinking of doing 2.5" out of each turbo into the intercooler then go 4" out of the turbo to the T-body. anyone know how much power this will support?
Thanks
Thanks
How big are your turbos? t4's or t3/t4's? I would imagine that as long as you don't go smaller than the compressors I.D.'s outlet it should be able to support what your whole set-up could produce (just remember that you'll have two of them = 5"), and I'm assuming you meant 4" from I.C. to T.B.??..which is plenty big (same O.D. on T.B.'s).
