Headers and exhaust
Old 05-06-2007, 07:30 PM
Ridnkawie4life's Avatar
Default Headers and exhaust
I am gettin long tube headers and i would like some input to what i kind i should get and what i should put after the y pipe, i want true duals but i have no idea WHERE to get them...input please..
Old 05-06-2007, 08:22 PM
Stroker396@APF's Avatar
Surprised no one has responded.
Well I have mids but first technically you won't have a Y pipe if you want true duals. A Y pipe is where the two pipes merge as one. Perhaps an X pipe but there is no room in the tunnel for dual pipes.
The pictures I have seen of Dual setups have the mufflers coming off the LT's and shaved tips up deep under the car.
This greatly reduces the ground clearance as there is not much room on the drivers side.
I don't know who if anyone makes a true dual all in one kit setup for the LT1 F bodies
Old 05-13-2007, 09:26 AM
That_guy's Avatar
if ur on a budget get pacesetters, if you have a lil bit of money get hooker lts, if you have a bank then get kooks or qtp if you get qtp you can order them with the electric cutouts.
