General LSX Automobile Discussion Non-technical LSX related topics.
what gauges for my pod??
Old 05-06-2007, 11:47 PM
yzblue125's Avatar
Default what gauges for my pod??
Got the Two pod Pillar thing...Whats Gauges should I put in it??? 1999 Z28
Old 05-06-2007, 11:48 PM
Starz T/A 17's Avatar
probally temp should be one of them since all the 99+ cars were dummy gauges
Old 05-06-2007, 11:54 PM
yzblue125's Avatar
If I put a temp gauge in it will it turn off the old gauge? Also when I was looking at them at Oreilys there was and electric one or Manuall. Which one does the Z28 use.
Old 05-07-2007, 12:02 AM
no, you have to leave the stock one in there b/c I think the PCM uses it, but what most people do is either tap the water pump or use the water outet plug in the back of the passenger side head
Old 05-07-2007, 09:47 PM
6-Speed Terror's Avatar
you will want the electrical one i have that one it is nice. i would say a/f but i had that one 2 but it will go all over the place and really does not give you accurate readings.
Old 05-07-2007, 10:37 PM
BriancWS6's Avatar
Well I see you have a dry kit in your sig. SO, my suggestion would be a wideband and n2o pressure.
Old 05-08-2007, 12:58 AM
BayAreaSS's Avatar
......+1
Old 05-08-2007, 02:49 AM
NKAWTG...N
StoleIt's Avatar
If your not FI stop ebing gay and invest in somethig that matters. but ive been drinking so just aying itlike it should IMO
Old 05-08-2007, 12:26 PM
Fibbado's Avatar
Nah, maybe fuel pressure if your running N20... and N20 pressure. Although I kind of like the N20 switch plate/ press guage that Nitrous outlet makes.
Fuel pressure and Water Temp.
Old 05-08-2007, 12:33 PM
ZFan88's Avatar
wideband and n20 pressure
