Problems with idle!!
Old 05-07-2007, 09:26 AM
Randy_S's Avatar
Default Problems with idle!!
My car is having an occassional problem holding idle when I come to a stop. I have a 612 lift cam which I assume contributes to that partially but if I feather the throttle a little it comes back up to normal idle. It just wants to die out like its not getting any air or fuel.
Any suggestions??
Old 05-07-2007, 12:30 PM
STILL 2 SLOW's Avatar
Mine did that for a while and I took it back to my tuner and he made some corrections and now its gone. I would have the tune checked out.
Old 05-07-2007, 03:16 PM
Randy_S's Avatar
Do you know what he changed for that? I called GForce this morning and they recommended that I check my throttle body to see if there is a little hole in the plate for air to pass when idleing. As if it is getting choked off when I let off of it.
