Anyone sell ls6 clutch without flywheel?
I ordered a ls7 clutch kit from byunspeed only to find out they are backordered. I need a clutch asap. Does anyone sell the ls6 clutch without the flywheel? I would like to buy an aluminum one. Thanks.
Alright after a lot of searching the only thing I found is this (select make, model, year)
http://www.gripforce.com/clutch.asp
LUK OEM Pressure Plate
LUK OEM Flywheel
LUK OEM Clutch Disc
Release Bearing
Pilot Bearing
Alignment Tool
Dont need release bearing but this sounds like a deal. I could save about $100 without buying the flywheel. Does anyone know anything about this company? I did some searching and found nothing recent about them. I know they used to be a sponsor.
LUK OEM Flywheel
LUK OEM Clutch Disc
Release Bearing
Pilot Bearing
Alignment Tool
