General Maintenance & Repairs - 50 amp ingnition fuse blowing
I have been blowing the 50 amp ingnition fuse under the hood on my 2001 z28.Does anyone know what would cause this issue,it just began happening
this year when it came out to play after winter.
staringback05
05-08-2007, 12:52 PM
you could have a bad ground, a wire on wire, or a frayed end....check loads on wires..
I took the odessy battery out put in a fully charged optima red top, drove it to work with no problems.Shut the car off,tried to restart it and blew the fuse again.Put in a new fuse but still no crank.HELP!!!!
blownta00
05-11-2007, 01:03 PM
check your grounds man
Black02SLPSS
02-22-2008, 04:58 PM
Bringin this one back from the dead. Im having the same problem. z-ya did you ever get yours figured out?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
