Wheel hop??
I have an automatic 07. I eliminated mine with Z06 shocks. I had previously installed a Z51 rear bar with polyurethane bushings and still had wheel hop. Combination of both, I doubt. I think the shocks were the key but can't say for sure that it did not take both.
Originally Posted by DarkC5
move to a softer compound tire. drag radials work wonders
You will still get wheel hop with sticky tires when doing a burn out. Once they start to grab be ready. If you don't have to do a burn out then you may not get wheel hop with the stickys.
Like said abovem the tires you have will reduce the problem. But no matter what kind of tire you have you can still get wheel hop. Wheel hop is caused by the tires trying to catch up to each other. The tires flex and will wobble out of balance causing wheel hop.
Wheel hop is expensive and will break halfshafts, replacements are about $400 a piece.
