Smaller alternator?
Smaller alternator?
I may have to notch my crossmember for the alternator, and I really don't want to do that. Is there a comparable alternator that is smaller in diameter and maybe shorter? I can make my own bracket, so I am not really worried about that, but I am concerned if it will function with the factory pcm. Any ideas?
sawzall wielding director
You do not necessarily have to interface the PCM with the alternator. Since you are talking about crossmember clearance I am guessing that you are using f-body brackets. If it is a 98 PCM it does not interface with the alt at all. If it is 99+ at the most you would have to have a couple of codes deleted. As long as the alternator is big enough to keep the battery charged the PCM will be happy. I don`t have any recommendations for a smaller alt. How about switching to truck accys? that would move the alt to the top and the PS pump to the bottom. The PS pump is shorter and should fit. If you have hood clearance that might be a solution.
Thanks, G-body. I just bought the f-body brackets because I hate the alternator being up high, so if I have to notch the crossmember, so be it. The engine compartment has to look clean, at all costs, you know?
Moral of the story:
Don`t take a shortcut on the first time, or you`ll kick yourself later
That's why I am trying to convince the wife to pad the coffer a little more I don't want those headaches after the fact. I know that more money spent now equals less problems in the future. Is that what the crossmember under the engine is called, the K member, or is that only for your body?
